VB 自动配置IIS
2014年3月26日 1:16 本文热度 6946
'建立活动桌面'(IADS)对象,首先要引用 Active DS Type library 组件
Dim WWWServer As IADs, WWWService As IADs, WWWVDir, WWWVdirRes As IADs
Function CreateWebSite(ByVal WWWSiteName As String, _
ByVal WWWSitePort As String, _
ByVal WWWSitePath As String, _
ByVal WWWHostName As String, _
ByVal ComputerName As String) As Boolean
'变量定义
Dim SiteExist As Boolean
Dim
WebName
'变量初始化
SiteExist = False
WebName = 1
CreateWebSite = True
On Error Resume Next
Err.Clear
'取得W3SVC服务
Set WWWService = GetObject("IIS://" & ComputerName & "/W3SVC")
Do While Err.Number <> 0
Err.Clear
Loop
Err.Clear
'出错处理
'在IIS中查找每一个WEB站点
For Each WWWServer In WWWService
If UCase(Trim(WWWServer.ServerComment)) <> UCase(Trim(WWWSiteName)) Then
If
IsNumeric(WWWServer.Name) Then
If CInt
(WWWServer.Name) >= WebName Then WebName = CInt(WWWServer.Name) + 1
End If
Else
SiteExist = True
Exit For
End If
Next
If
SiteExist Then
MsgBox "该站点已经存在!", vbInformation + vbOKOnly, "系统信息"
Exit Function
End If
'创建WebServer
Set WWWServer = WWWService.Create("IISWebServer", WebName) '创建新站点
WWWServer.ServerComment = WWWSiteName '设置站点名
WWWServer.KeyType = "IISWebServer"
WWWServer.ServerBindings = ":" & WWWSitePort & ":" & WWWHostName '设置端口号和主机头
WWWServer.DefaultDoc = "Default.asp,Index.asp,Default.htm,Index.htm" '设置默认启动文件
WWWServer.AccessScript = True '设置权限
WWWServer.AccessRead = True
WWWServer.FrontPageWeb = True
WWWServer.EnableDefaultDoc = True
WWWServer.DefaultDoc = "Default.htm, Default.asp, Index.htm, Index.asp"
Set WWWVDir = WWWServer.Create("IISWebVirtualDir", "Root")
WWWVDir.Path = WWWSitePath
WWWVDir.AppCreate
True
WWWVDir.SetInfo
WWWServer.SetInfo
WWWServer.Start
MsgBox
"主机设置成功!", vbInformation + vbOKOnly, "系统信息"
'Set WWWVdirRes = WWWVdir.Create("IISWebVirtualDir", "Resource") '创建虚拟目录
'WWWVdirRes.Path = WWWFilesPath + "\Resource"
'WWWVdirRes.AccessRead = True
'WWWVdirRes.AccessWrite = True
'WWWVdirRes.SetInfo
'下面为自定义IIS Web Server的错误信息,等发生404错误时候指定调用网站主目录下的404.htm页面显示
'WWWServer.HttpErrors = "404,0,FILE," + WWWFilesPath + "\404.htm"
'WWWServer.SetInfo
End Function
Function
DeleteWebSite(ByVal WWWSiteName As String, ByVal ComputerName As String) As Boolean
'定义变量
Dim Tmp As Integer
Dim
WebName
'变量初始化
SiteExist = False
DeleteWebSite = True
'取得W3SVC服务
Err.Clear
Err.Clear
Loop
Err.Clear
SiteExist = False
Else
If
WebName = WWWServer.Name
End If
SiteExist = True
Exit For
End If
Next
'删除站点
WWWService.Delete "IISWebServer", WebName
MsgBox
"主机删除成功!", vbInformation + vbOKOnly, "系统信息"
End Function
Private Sub
cmdCreateWebSite_Click()
CreateWebSite txtSiteName.Text, txtSitePort.Text, txtSitePath.Text, txtHostName.Text, txtComputerName.Text
End Sub
Private Sub
cmdDeleteWebSite_Click()
DeleteWebSite txtSiteName.Text, txtComputerName.Text
End Sub
该文章在 2014/3/26 1:16:54 编辑过
全部评论1
2014年3月26日 1:18
使用vbscript自动配置IIS
最近因为参与一项WEB工程的缘故,写了一个VBScript的程序,用于配置IIS的虚拟目录。
特写出来大家一起分享。
源程序如下:(已在Win2000通过)
strServerName ="localhost"
strRootPath="g:documents" ''虚拟目录路径
strVRName="Test" ''虚拟目录名称
strDefaultDoc="index.asp" ''起始文档
Dim objIIS
''MsgBox "IIS://" & strServerName & "/W3SVC/1"
Set objIIS=GetObject("IIS://" & strServerName & "/W3SVC/1")
If err=-2147024893 Then
MsgBox "IIS不存在!" & vbcrlf & "请验证IIS是否已正确安装!",vbcritical
Wscript.Quit
ElseIf err<>0 Then
MsgBox "未知错误!",vbcritical
Wscript.Quit
End If
On Error GoTo 0
Set objVirtualDir=objIIS.GetObject("IISWebVirtualDir","Root")
For each VR in objVirtualDir
If VR.Name=strVRName Then
MsgBox "虚拟目录" & strVRName & "已存在!",vbinformation
Wscript.Quit
End If
Next
Set fs=Wscript.CreateObject("Scripting.FileSystemObject")
Set objFolder=fs.GetFolder(strRootPath)
If err=76 Then
MsgBox "路径" & strRootPath & "不存在!",vbcritical
Wscript.Quit
End If
Set objFolder=nothing
Set fs=nothing
On Error GoTo 0
Set VirDir=objVirtualDir.Create("IISWebVirtualDir",strVRName)
VirDir.AccessRead=true
VirDir.Path=strRootPath
VirDir.DefaultDoc=VirDir.DefaultDoc & "," & strDefaultDoc
VirDir.setInfo
If err<>0 Then
MsgBox "创建虚拟目录失败!",vbcritical
Else
MsgBox "虚拟目录" & strVRName & "成功创建在服务器" & strServerName & "上!",vbinformation
End If
代码的关键在于创建虚拟目录,及其中的配置:
VirDir.setInfo
该评论在 2014/3/26 1:18:38 编辑过
