C#使用XDocument操作XML格式数据
								2025年7月24日 14:56
								本文热度 1333
				XDocument是C#中LINQ to XML的核心类,它提供了一种更现代、更直观的方式来处理XML数据。相比传统的XmlDocument,XDocument更加简洁易用。开发软件:Visual Studio 2019
核心组件:LINQ to XML (System.Xml.Linq)辅助组件:System.Xml, System.IO一.创建一个C#窗台程序用来演示C#操作XML,生成XML格式数据<?xml version="1.0"?><res>  <Code>0</Code>  <Desc>成功</Desc>  <Info>    <Code>1</Code>    <Name>小明</Name>  </Info>  <Info>    <Code>2</Code>    <Name>大明</Name>  </Info>  <List>    <Info>      <Code>1</Code>      <Name>北京</Name>    </Info>    <Info>      <Code>2</Code>      <Name>上海</Name>    </Info>  </List></res>
            string[] username = { "小明", "大明" };            string[] city = { "北京", "上海" };
                        XDocument doc = new XDocument();            XDeclaration xDeclaration = new XDeclaration("1.0", "utf-8", null);            doc.Declaration = xDeclaration;
                        XElement xEres = new XElement("res");            XElement xDCode = new XElement("Code", "0");            XElement xDDesc = new XElement("Desc", "成功");            xEres.Add(xDCode);            xEres.Add(xDDesc);
                        for (int i = 0; i < username.Length; i++)            {                XElement xEInfo = new XElement("Info");
                XElement Code = new XElement("Code", (i + 1).ToString());                xEInfo.Add(Code);
                XElement Name = new XElement("Name", username[i]);                xEInfo.Add(Name);
                xEres.Add(xEInfo);            }
                        XElement List = new XElement("List");            for (int i = 0; i < city.Length; i++)            {                XElement xEInfo = new XElement("Info");
                XElement Name = new XElement("Name", city[i]);                xEInfo.Add(Name);
                List.Add(xEInfo);            }            xEres.Add(List);
            doc.Add(xEres);
            richTextBox1.Text = XmlToString(doc).ToString();
        public static string XmlToString(XDocument doc)        {            string xmlString;            using (var writer = new StringWriter())            {                using (var xmlWriter = XmlWriter.Create(writer))                {                    doc.WriteTo(xmlWriter);                }                xmlString = writer.ToString();            }            return xmlString;        }
            XDocument doc = XDocument.Parse(richTextBox1.Text);            XElement res = doc.Element("res");
                        string str_Code = res.Element("Code").Value;            string str_Desc = res.Element("Desc").Value;            richTextBox2.AppendText("Code:" + str_Code);            richTextBox2.AppendText("-");            richTextBox2.AppendText("Desc:" + str_Desc);            richTextBox2.AppendText("\r\n");
                        var xEInfos = res.Elements("Info");
            foreach (XElement info in xEInfos)            {                string str_InfoCode = info.Element("Code").Value;                string str_InfoName = info.Element("Name").Value;
                richTextBox2.AppendText("userCode:" + str_InfoCode);                richTextBox2.AppendText("-");                richTextBox2.AppendText("userName:" + str_InfoName);                richTextBox2.AppendText("\r\n");            }
                        XElement List = res.Element("List");            var Infos = List.Elements("Info");
            foreach (XElement info in Infos)            {                string str_InfoCode = info.Element("Code").Value;                string str_InfoName = info.Element("Name").Value;
                richTextBox2.AppendText("cityCode:" + str_InfoCode);                richTextBox2.AppendText("-");                richTextBox2.AppendText("cityName:" + str_InfoName);                richTextBox2.AppendText("\r\n");            }
该文章在 2025/7/24 14:56:23 编辑过
