C#实现文件上传和接收功能
								2025年7月22日 18:6
								本文热度 1064
				using System;using System.IO;using System.Web;using System.Web.Http;
namespace Mes.Controllers{    public class FileController : ApiController    {        [HttpPost]        public string UploadFile()        {            string result = string.Empty;            try            {                                string fileName = HttpContext.Current.Request.Files[0].FileName;                Stream stream = HttpContext.Current.Request.Files[0].InputStream;
                               var forms = HttpContext.Current.Request.Form;                foreach (var item in forms)                {                    string val = forms[item.ToString()];                }                                string uploadFolder = "F:\\图片";                string savePath = System.IO.Path.Combine(uploadFolder, fileName);                FileStream fsWrite = new FileStream(savePath, FileMode.Create);
                byte[] bytes = new byte[1024 * 4];                int total = 0;                int size = 0;                do                {                                        size = stream.Read(bytes, 0, bytes.Length);                    fsWrite.Write(bytes, 0, size);                    total += size;                }                while (size > 0);
                fsWrite.Close();                result = "true";            }            catch (Exception ex)            {                result = ex.Message;            }            return result;        }    }}
using System.Net;using System.Net.Http;using System.Net.Http.Headers;
public string PostFile(string url, Dictionary<string, object> dics, string filePath){string result = string.Empty;try	{		MultipartFormDataContent form = new MultipartFormDataContent();using (HttpClient client = new HttpClient())		{			MediaTypeWithQualityHeaderValue temp = new MediaTypeWithQualityHeaderValue("application/json") { CharSet = "utf-8" };			client.DefaultRequestHeaders.Accept.Add(temp);
foreach (var keyValuePair in dics)			{				form.Add(new StringContent(keyValuePair.Value.ToString()), keyValuePair.Key);			}
			Stream fileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read);var fileName = Path.GetFileName(filePath);
			form.Add(new StreamContent(fileStream), "file", fileName);
			Task<HttpResponseMessage> task = client.PostAsync(url, form);			task.Wait(); 			HttpResponseMessage response = task.Result;			response.EnsureSuccessStatusCode();
string responseBody = task.Result.Content.ReadAsStringAsync().Result;			Console.WriteLine(responseBody);			result = responseBody;		}return result;	}catch (Exception ex)	{throw new Exception(ex.Message);	}}
using (var fileStream = new FileStream(filePath, FileMode.Open, FileAccess.Read))			{byte[] data = new byte[fileStream.Length];				fileStream.Read(data, 0, data.Length);				fileStream.Close();
var fileName = Path.GetFileName(filePath);				form.Add(new ByteArrayContent(data), "file", fileName);			}
该文章在 2025/7/23 12:17:41 编辑过
