C#操作ORACL数据库调用ORACL存储过程
2025年7月11日 14:41 本文热度 1501
一、执行存储过程
        /// <summary>        /// 执行存储过程        /// </summary>        /// <param name="SQLString"></param>        /// <returns></returns>        public static Boolean SqlProcedure(string SQLString)        {            using (OracleConnection connection = new OracleConnection(connectionString))            {                try                {                    connection.Open();                    OracleCommand command = new OracleCommand(SQLString, connection);                    int recordCount = command.ExecuteNonQuery();
                    return true;                }                catch (Exception ex)                {                    LogHelper.WriteErrorLog("SQL:" + SQLString, ex);                    Global.strMessage = ex.Message.ToString();                    return false;                    throw new Exception(ex.Message);                }                finally                {                    connection.Close();                }            }        }
二、一次执行多个存储过程,带事务回滚
/// <summary>        /// 执行存储过程        /// </summary>        /// <param name="SQLArrayList"></param>        /// <returns></returns>        public static Boolean SqlProcedure(ArrayList SQLArrayList)        {            using (OracleConnection connection = new OracleConnection(connectionString))            {                connection.Open();                OracleTransaction transaction = connection.BeginTransaction();
                try                {                    for (int i = 0; i < SQLArrayList.Count; i++)                    {                        string SQLString = SQLArrayList[i].ToString();                        OracleCommand command = new OracleCommand(SQLString, connection);                        command.ExecuteNonQuery();                    }                    transaction.Commit();                    return true;                }                catch (Exception ex)                {                    transaction.Rollback();                    Common.Global.strMessage = ex.Message.ToString();                    return false;                    throw new Exception(ex.Message);                }                finally                {                    connection.Close();                }            }        }
三、执行XmlType类型返回值的存储过程
        /// <summary>        /// 执行带返回值的存储过程        /// </summary>        /// <param name="CunChuName"></param>        /// <param name="parm"></param>        /// <returns></returns>        public static string RunProcedures(string CunChuName, OracleParameter[] parm)        {            string strOut = "";            OracleCommand cmd = new OracleCommand();            using (OracleConnection conn = new OracleConnection(connectionString))            {                try                {                    cmd.CommandType = CommandType.StoredProcedure;                    cmd.CommandText = CunChuName;                    for (int i = 0; i < parm.Length; i++)                    {                        cmd.Parameters.Add(parm[i]);                    }                    if (conn.State != ConnectionState.Open)                        conn.Open();
                    cmd.Connection = conn;                    cmd.ExecuteNonQuery();
                    //返回参数                    strOut = ((Oracle.ManagedDataAccess.Types.OracleXmlType)cmd.Parameters["Xml_Out"].Value).Value;
                    return strOut;                }                catch (Exception ex)                {                    Common.Global.strMessage = ex.Message.ToString();                    LogHelper.WriteErrorLog("CunChuName:" + CunChuName, ex);                    return strOut;                }                finally                {                    if (conn.State == ConnectionState.Open)                        conn.Close();                    conn.Dispose();                    cmd.Parameters.Clear();                    cmd.Dispose();                }            }
该文章在 2025/7/11 14:41:22 编辑过
