【C#】关于使用WinRAR进行文件的RAR、ZIP格式解压和压缩操作
2025年2月13日 17:11 本文热度 1617
1. 利用 WinRAR 进行解压缩
using System;
using System.Text;
using System.IO;
using System.Diagnostics;
using Microsoft.Win32;
namespace RarClass
    public class unrar
    public void unCompressRAR(string unRarPatch, string rarPatch, string rarName)
            string the_rar;
            RegistryKey the_Reg;
            object the_Obj;
            string the_Info;
            the_Reg = Registry.LocalMachine.OpenSubKey(@"SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\WinRAR.exe");
            the_Obj = the_Reg.GetValue("");
            the_rar = the_Obj.ToString();
            the_Reg.Close();
            //the_rar = the_rar.Substring(1, the_rar.Length – 7);
            if (Directory.Exists(unRarPatch) == false)
                Directory.CreateDirectory(unRarPatch);
            the_Info = "x  -y  " + rarName + " " + unRarPatch ;
            ProcessStartInfo the_StartInfo = new ProcessStartInfo();
            the_StartInfo.FileName = the_rar;
            the_StartInfo.Arguments = the_Info;
            the_StartInfo.WindowStyle = ProcessWindowStyle.Hidden;
            the_StartInfo.WorkingDirectory = rarPatch;//获取压缩包路径
            Process the_Process = new Process();
            the_Process.StartInfo = the_StartInfo;
            the_Process.Start();
            the_Process.WaitForExit();
            the_Process.Close();
2. 利用 WinRAR 进行解压缩
/// <summary>
/// 利用 WinRAR 进行压缩
/// </summary>
/// <param name="path">将要被压缩的文件夹(绝对路径)</param>
/// <param name="rarPath">压缩后的 .rar 的存放目录(绝对路径)</param>
/// <param name="rarName">压缩文件的名称(包括后缀)</param>
/// <returns>true 或 false。压缩成功返回 true,反之,false。</returns>
public bool RAR(string path, string rarPath, string rarName)
    bool flag = false;
    string rarexe;       //WinRAR.exe 的完整路径
    RegistryKey regkey;  //注册表键
    Object regvalue;     //键值
    string cmd;          //WinRAR 命令参数
    ProcessStartInfo startinfo;
    Process process;
    try
        regkey = Registry.ClassesRoot.OpenSubKey(@"Applications\WinRAR.exe\shell\open\command");
        regvalue = regkey.GetValue("");  // 键值为 "d:\Program Files\WinRAR\WinRAR.exe" "%1"
        rarexe = regvalue.ToString();
        regkey.Close();
        rarexe = rarexe.Substring(1, rarexe.Length - 7);  // d:\Program Files\WinRAR\WinRAR.exe
        Directory.CreateDirectory(path);
        //压缩命令,相当于在要压缩的文件夹(path)上点右键->WinRAR->添加到压缩文件->输入压缩文件名(rarName)
        cmd = string.Format("a {0} {1} -r", rarName, path);
        startinfo = new ProcessStartInfo();
        startinfo.FileName = rarexe;
        startinfo.Arguments = cmd;                          //设置命令参数
        startinfo.WindowStyle = ProcessWindowStyle.Hidden;  //隐藏 WinRAR 窗口
        startinfo.WorkingDirectory = rarPath;
        process = new Process();
        process.StartInfo = startinfo;
        process.Start();
        process.WaitForExit(); //无限期等待进程 winrar.exe 退出
        if (process.HasExited)
            flag = true;
        process.Close();
    catch (Exception e)
        throw e;
    return flag;
/// <summary>
/// 利用 WinRAR 进行解压缩
/// </summary>
/// <param name="path">文件解压路径(绝对)</param>
/// <param name="rarPath">将要解压缩的 .rar 文件的存放目录(绝对路径)</param>
/// <param name="rarName">将要解压缩的 .rar 文件名(包括后缀)</param>
/// <returns>true 或 false。解压缩成功返回 true,反之,false。</returns>
public bool UnRAR(string path, string rarPath, string rarName)
    bool flag = false;
    string rarexe;
    RegistryKey regkey;
    Object regvalue;
    string cmd;
    Process process;
    try
        regkey.Close();
        rarexe = rarexe.Substring(1, rarexe.Length - 7);//解压缩命令,相当于在要压缩文件(rarName)上点右键->WinRAR->解压到当前文件夹
        cmd = string.Format("x {0} {1} -y",
                            rarName,
                            path);
        startinfo.WindowStyle = ProcessWindowStyle.Hidden;= rarPath;
        process.Start();
            flag = true;
        process.Close();
    catch (Exception e)
        throw e;
    return flag;
昨天又看了下,发现如果路径中有空格(如:D:\Program Files\)的话压缩解压就会出现问题,折磨了我很长时间,最后实在没办法了就在cmd里面试了半天,发现在有空格的路径上加双引号就可以了。在代码里Directory.CreateDirectory(path);后面把 path 和 rarName 都判断一下如果有空格,就加上 path = "\"" + path + "\"";
3. 本次示例主要实现:
  • 1.压缩文件夹及其下文件
  • 2.压缩文件夹下文件
  • 3.压缩文件夹及其下文件为rar 还是 zip
  • 4.解压缩
  • 5.加密压缩及解加密压缩
示例代码如下:
protected void Button1_Click(object sender, EventArgs e)
    string strtxtPath = "C:\\freezip\\free.txt";
    string strzipPath = "C:\\freezip\\free.zip";
    System.Diagnostics.Process Process1 = new System.Diagnostics.Process();
    Process1.StartInfo.FileName = "Winrar.exe";
    Process1.StartInfo.CreateNoWindow = true;
    //1、压缩c:\freezip\free.txt(即文件夹及其下文件freezip\free.txt)到c:\freezip\free.rar
    //strzipPath = "C:\\freezip\\free";//默认压缩方式为 .rar
    //Process1.StartInfo.Arguments = " a -r " + strzipPath + " " + strtxtPath;
    //2、压缩c:\freezip\free.txt(即文件夹及其下文件freezip\free.txt)到c:\freezip\free.rar
    //strzipPath = "C:\\freezip\\free";//设置压缩方式为 .zip
    //Process1.StartInfo.Arguments = " a -afzip " + strzipPath + " " + strtxtPath;
    //3、压缩c:\freezip\free.txt(即文件夹及其下文件freezip\free.txt)到c:\freezip\free.zip 直接设定为free.zip
    //Process1.StartInfo.Arguments = " a -r "+strzipPath+" " + strtxtPath ;
    //4、搬迁压缩c:\freezip\free.txt(即文件夹及其下文件freezip\free.txt)到c:\freezip\free.rar 压缩后 原文件将不存在
    //Process1.StartInfo.Arguments = " m " + strzipPath + " " + strtxtPath;
    //5、压缩c:\freezip\下的free.txt(即文件free.txt)到c:\freezip\free.zip 直接设定为free.zip 只有文件 而没有文件夹
    //Process1.StartInfo.Arguments = " a -ep " + strzipPath + " " + strtxtPath;
    //6、解压缩c:\freezip\free.rar到 c:\freezip\
    //strtxtPath = "c:\\freezip\\";
    //Process1.StartInfo.Arguments = " x " + strzipPath + " " + strtxtPath;
    //7、加密压缩c:\freezip\free.txt(即文件夹及其下文件freezip\free.txt)到c:\freezip\free.zip 密码为123456 注意参数间不要空格
    //Process1.StartInfo.Arguments = " a -p123456 " + strzipPath + " " + strtxtPath;
    //8、解压缩加密的c:\freezip\free.rar到 c:\freezip\ 密码为123456 注意参数间不要空格
    //Process1.StartInfo.Arguments = " x -p123456 " + strzipPath + " " + strtxtPath;
   //9、-o+ 覆盖 已经存在的文件; -o- 不覆盖 已经存在的文件
   //Process1.StartInfo.Arguments = " x -o+ " + strzipPath + " " + strtxtPath;
   //10、只从指定的zip中解压出free1.txt到指定路径下压缩包中的其他文件 不予解压
   //Process1.StartInfo.Arguments = " x " + strzipPath + " " +" free1.txt" + " " + strtxtPath;
   //11、通过 -y 对所有询问回应为"是" 以便 即便发生错误 也不弹出WINRAR的窗口 -cl 转换文件名为小写字母
   //Process1.StartInfo.Arguments = " t -y -cl " + strzipPath + " " + " free1.txt";
    Process1.Start();
    if (Process1.HasExited)
       int iExitCode = Process1.ExitCode;
        if (iExitCode == 0)
            Response.Write(iExitCode.ToString() + " 正常完成");
            Response.Write(iExitCode.ToString() + " 有错完成");
4. C#调用rar.exe解压一个rar文件到系统的临时目录
//C#调用rar.exe解压一个rar文件到系统的临时目录:
//取得系统临时目录
string sysTempDir = Path.GetTempPath();
//要解压的文件路径,请自行设置
string rarFilePath = @"d:\test.rar";
//确定要解压到的目录,是系统临时文件夹下,与原压缩文件同名的目录里
string unrarDestPath = Path.Combine(sysTempDir, Path.GetFileNameWithoutExtension(rarFilePath));
//组合出需要shell的完整格式
string shellArguments = string.Format("x -o+ \"{0}\" \"{1}\\\"", rarFilePath, unrarDestPath);
//用Process调用
using (Process unrar = new Process())
    unrar.StartInfo.FileName = "rar.exe";
    unrar.StartInfo.Arguments = shellArguments;
    //隐藏rar本身的窗口
    unrar.StartInfo.WindowStyle = ProcessWindowStyle.Hidden;
    unrar.Start();
    //等待解压完成
    unrar.WaitForExit();
    unrar.Close();
//统计解压后的目录和文件数
DirectoryInfo di = new DirectoryInfo(unrarDestPath);
MessageBox.Show(string.Format("解压完成,共解压出:{0}个目录,{1}个文件", di.GetDirectories().Length, di.GetFiles().Length));
该文章在 2025/2/13 17:12:42 编辑过
