分享一些不错的JS/TS代码片段
2025年1月24日 15:12 本文热度 1558
方法顺序执行,不论同步还是异步
以下代码实现方法顺序执行,不论同步还是异步,
let result;
for (const f of [func1, func2, func3]) {
  result = await f(result);
/* use last result (i.e. result3) */
更老版本的写法:
const applyAsync = (acc, val) => acc.then(val);
const composeAsync =
  (...funcs) =>
  (x) =>
    funcs.reduce(applyAsync, Promise.resolve(x));
const transformData = composeAsync(func1, func2, func3);
const result3 = transformData(data);
参考:MDN: 使用Promise[1]
闭包缓存计算结果,提高性能
function memoize(fn{
    const cache = {};
    return function(...args{
        const key = JSON.stringify(args);
        if (cache[key] !== undefined) {
            return cache[key];
        const result = fn(...args);
        cache[key] = result;
        return result;
function fibonacci(n{
    if (n <= 1) {
        return n;
    return fibonacci(n - 1) + fibonacci(n - 2);
const memoizedFibonacci = memoize(fibonacci);
console.log(memoizedFibonacci(10)); // 输出 55
console.log(memoizedFibonacci(20)); // 输出 6765
在这个例子中,memoize 函数通过闭包缓存了计算结果,提高了递归函数的性能。
闭包实现函数柯里化
通用的函数柯里化工具函数,注意这里没有处理this的指向
function curry(fn{
  return function curried(...args{
    if (args.length >= fn.length) {
      return fn(...args);
    return function (...nextArgs{
      return curried(...args, ...nextArgs);
function sum(a,b,c){
  return a+b+c;
const curriedSum = curry(sum);
console.log(curriedSum(1)(2)(3)); // 6
console.log(curriedSum(12)(3)); // 6
console.log(curriedSum(1)(23)); // 6
TypeScript
枚举+位运算进行状态判断
枚举+位运算进行状态判断与运算
enum AnimalFlags {
  None        = 0,
  HasClaws    = 1 << 0,
  CanFly      = 1 << 1
interface Animal {
  flags: AnimalFlags;
  [key: string]: any;
function printAnimalAbilities(animal: Animal{
  var animalFlags = animal.flags;
  if (animalFlags & AnimalFlags.HasClaws) {
    console.log('animal has claws');
  if (animalFlags & AnimalFlags.CanFly) {
    console.log('animal can fly');
  if (animalFlags == AnimalFlags.None) {
    console.log('nothing');
var animal = { flags: AnimalFlags.None };
printAnimalAbilities(animal); // nothing
animal.flags |= AnimalFlags.HasClaws;
printAnimalAbilities(animal); // animal has claws
animal.flags &= ~AnimalFlags.HasClaws;
animal.flags |= AnimalFlags.HasClaws | AnimalFlags.CanFly;
printAnimalAbilities(animal); // animal has claws, animal can fly
Animal 有多种状态时判断、运算十分简洁
假如让我来写的话,不用枚举+位运算的话可能实现如下
type AnimalFlags = 'None' | 'HasClaws' | 'CanFly';
interface Animal {
  flags: AnimalFlags[];
  [key: string]: any;
  if (!animalFlags || animalFlags.includes('None')) {
    return 'nothing';
  if (animalFlags.includes('HasClaws')) {
  if (animalFlags.includes('CanFly')) {
var animal: Animal = { flags: ['None'] };
animal.flags = ['HasClaws'];
animal.flags = ['None'];
animal.flags = ['HasClaws''CanFly'];
运算不太方便,比如状态是['HasClaws', 'CanFly'], 想移除Fly状态需要进行数组操作,比位运算麻烦许多
参考:深入理解 TypeScript:枚举[2]
React 导出 useImperativeHandle 的声明
定义:
type CountdownProps = {}
type CountdownHandle = {
  start: () => void,
const Countdown: React.ForwardRefRenderFunction<CountdownHandle, CountdownProps> = (
  props,
  forwardedRef,
  React.useImperativeHandle(forwardedRef, ()=>({
    start() {
      alert('Start');
  return <div>Countdown</div>;
export default React.forwardRef(Countdown);
在上层组件中常想知道子组件useImperativeHandle的定义,可以这么写:
const App: React.FC = () => {
  // 这个类型等于 `CountdownHandle`,但不需要手动 import CountdownHandle
  type CountDownRef = React.ElementRef<typeof Countdown>;
  const ref = React.useRef<CountDownRef>(null); // assign null makes it compatible with elements.
  return (
    <Countdown ref={ref} />
CountDownRef这个类型等于 CountdownHandle,但不需要手动 import CountdownHandle
参考:stackoverflow[3]
+ -修饰符
+ -修饰符可以添加或去掉readonly 和 ?,如
type CreateMutable<Type> = {
  -readonly [Property in keyof Type]: Type[Property];
type LockedAccount = {
  readonly id: string;
  readonly name: string;
type UnlockedAccount = CreateMutable<LockedAccount>;
// UnlockedAccount 等效于
type UnlockedAccount = {
通过as重新映射类型
在TypeScript 4.1及更高版本中,可以在映射类型中使用as子句重新映射映射类型中的键,形式如下:
type MappedTypeWithNewProperties<Type> = {
    [Properties in keyof Type as NewKeyType]: Type[Properties]
示例一,根据已知类型的键映射出新类型键
Capitalize[4]: 转换字符串类型第一个字母为大写
type Getters<Type> = {
    [Property in keyof Type as `get${Capitalize<string & Property>}`]: () => Type[Property]
interface Person {
    age: number;
type LazyPerson = Getters<Person>;
// 最终LazyPerson 等效于
type LazyPerson = {
    getName: () => string;
    getAge: () => number;
    getLocation: () => string;
示例二:映射任意联合类型
如:映射联合对象类型,并以类型的Value为新类型的key
type EventConfig<Events extends { kind: string }> = {
    [E in Events as E["kind"]]: (event: E) => void;
type SquareEvent = { kind: "square", x: number, y: number };
type CircleEvent = { kind: "circle", radius: number };
type Config = EventConfig<SquareEvent | CircleEvent>
// 最终config等效于
type Config = {
    square: (event: SquareEvent) => void;
    circle: (event: CircleEvent) => void;
该文章在 2025/1/24 16:54:47 编辑过
