【ASP】读取写入 JSON for Classic ASP 类下载(aspjson1.19-master.zip)
2024年12月12日 17:30 本文热度 4003
附件:aspjson1.19-master.zip
aspjson
Classic ASP JSON Class Reading/Writing
ASPJSON is a free to use project for generating and reading JSON data into a classic ASP object. The class can be used for reading a string of JSON data as well as writing JSON output from an AJAX file. Below are 2 simple examples of both.
Read Json Example:
Json内容:
  "firstName": "John",
  "lastName" : "Smith",
  "age"      : 25,
  "address"  :
    "streetAddress": "21 2nd Street",
    "city"         : "New York",
    "state"        : "NY",
    "postalCode"   : "10021"
  "phoneNumbers":
        "type"  : "home",
        "number": "212 555-1234"
        "type"  : "fax",
        "number": "646 555-4567"
读取Json代码:
Set oJSON = New aspJSON
'Load JSON string
oJSON.loadJSON(jsonstring)
'Get single value
Response.Write oJSON.data("firstName") & "<br>"
Response.Write oJSON.data("address").item("streetAddress") & "<br>"
'Loop through collection
For Each phonenr In oJSON.data("phoneNumbers")
    Set this = oJSON.data("phoneNumbers").item(phonenr)
    Response.Write _
    this.item("type") & ": " & _
    this.item("number") & "<br>"
Next
'Update/Add value
oJSON.data("firstName") = "James"
'Return json string
Response.Write oJSON.JSONoutput()
Write Json Example:
Json内容:
  "familyName": "Smith",
  "familyMembers":
      "age": 41,
      "job":
        "function": "Webdeveloper",
        "salary": 70000
      "firstName": "Suzan",
      "age": 38,
      "interests":
        "Reading",
        "Tennis",
        "Painting"
      "firstName": "John Jr.",
      "age": 2.5
写入Json代码:
With oJSON.data
    .Add "familyName", "Smith"                      'Create value
    .Add "familyMembers", oJSON.Collection()
    With oJSON.data("familyMembers")
        .Add 0, oJSON.Collection()                  'Create unnamed object
        With .item(0)
            .Add "firstName", "John"
            .Add "age", 41
            .Add "job", oJSON.Collection()          'Create named object
            With .item("job")
                .Add "function", "Webdeveloper"
                .Add "salary", 70000
            End With
        End With
        .Add 1, oJSON.Collection()
        With .item(1)
            .Add "firstName", "Suzan"
            .Add "age", 38
            .Add "interests", oJSON.Collection()    'Create array
            With .item("interests")
                .Add 0, "Reading"
                .Add 1, "Tennis"
                .Add 2, "Painting"
            End With
        End With
        .Add 2, oJSON.Collection()
        With .item(2)
            .Add "firstName", "John Jr."
            .Add "age", 2.5
        End With
    End With
End With
Response.Write oJSON.JSONoutput()                   'Return json string
该文章在 2024/12/12 17:40:54 编辑过
