C#获取Windows进程监听的TCP/UDP端口实例
2024年3月9日 15:42 本文热度 2176
在Windows下用CMD netstat命令可以获得当前进程监听端口号的信息,如netstat -ano可以看到IP、port、状态和监听的PID。那么可以执行CMD这个进程得到监听的端口号信息,C#代码如下:
            //进程id
            int pid = ProcInfo.ProcessID;
            //存放进程使用的端口号链表
            List<int> ports = new List<int>();
            Process pro = new Process();
            pro.StartInfo.FileName = "cmd.exe";
            pro.StartInfo.UseShellExecute = false;
            pro.StartInfo.RedirectStandardInput = true;
            pro.StartInfo.RedirectStandardOutput = true;
            pro.StartInfo.RedirectStandardError = true;
            pro.StartInfo.CreateNoWindow = true;
            pro.Start();
            pro.StandardInput.WriteLine("netstat -ano");
            pro.StandardInput.WriteLine("exit");
            Regex reg = new Regex("\\s+", RegexOptions.Compiled);
            string line = null;
            ports.Clear();
            while ((line = pro.StandardOutput.ReadLine()) != null)
                line = line.Trim();
                if (line.StartsWith("TCP", StringComparison.OrdinalIgnoreCase))
                    line = reg.Replace(line, ",");
                    string[] arr = line.Split(',');
                    if (arr[4] == pid.ToString())
                        string soc = arr[1];
                        int pos = soc.LastIndexOf(':');
                        int pot = int.Parse(soc.Substring(pos + 1));
                        ports.Add(pot);
                else if (line.StartsWith("UDP", StringComparison.OrdinalIgnoreCase))
                    if (arr[3] == pid.ToString())
                        ports.Add(pot);
            pro.Close();
该文章在 2024/3/9 15:42:32 编辑过
