C#中图片与BASE64码互相转换
2023年8月22日 15:47 本文热度 2799
//图片转为base64编码的文本
private void button1_Click(object sender, EventArgs e)
OpenFileDialog dlg = new OpenFileDialog();
dlg.Multiselect = true;
dlg.Title = "选择要转换的图片";
dlg.Filter = "Image files (*.jpg;*.bmp;*.gif;*.png)|*.jpg*.jpeg;*.gif;*.bmp|AllFiles (*.*)|*.*";
if (DialogResult.OK == dlg.ShowDialog())
for (int i = 0; i < dlg.FileNames.Length; i++)
ImgToBase64String(dlg.FileNames[i].ToString());
//图片转为base64编码的文本
private void ImgToBase64String(string Imagefilename)
try
Bitmap bmp = new Bitmap(Imagefilename);
this.pictureBox1.Image = bmp;
FileStream fs = new FileStream(Imagefilename + ".txt", FileMode.create);
StreamWriter sw = new StreamWriter(fs);
MemoryStream ms = new MemoryStream();
bmp.Save(ms, System.Drawing.Imaging.ImageFormat.Jpeg);
byte[] arr = new byte[ms.Length];
ms.Position = 0;
ms.Read(arr, 0, (int)ms.Length);
ms.Close();
String strbaser64 = Convert.ToBase64String(arr);
sw.Write(strbaser64);
sw.Close();
fs.Close();
   // MessageBox.Show("转换成功!");
catch (Exception ex)
MessageBox.Show("ImgToBase64String 转换失败\nException:" + ex.Message);
//base64编码的文本转为图片
private void button2_Click(object sender, EventArgs e)
dlg.Title = "选择要转换的base64编码的文本";
dlg.Filter = "txt files|*.txt";
Base64StringToImage(dlg.FileNames[i].ToString());
//base64编码的文本转为图片
private void Base64StringToImage(string txtFileName)
try
FileStream ifs = new FileStream(txtFileName, FileMode.Open, FileAccess.Read);
StreamReader sr = new StreamReader(ifs);
String inputStr = sr.ReadToEnd();
byte[] arr = Convert.fromBase64String(inputStr);
MemoryStream ms = new MemoryStream(arr);
Bitmap bmp = new Bitmap(ms);
//bmp.Save(txtFileName + ".jpg", System.Drawing.Imaging.ImageFormat.Jpeg);
//bmp.Save(txtFileName + ".bmp", ImageFormat.Bmp);
//bmp.Save(txtFileName + ".gif", ImageFormat.Gif);
//bmp.Save(txtFileName + ".png", ImageFormat.Png);
ms.Close();
sr.Close();
ifs.Close();
this.pictureBox2.Image = bmp;
if (File.Exists(txtFileName))
File.delete(txtFileName);
//MessageBox.Show("转换成功!");
MessageBox.Show("Base64StringToImage 转换失败\nException:" + ex.Message);
该文章在 2023/8/22 15:47:08 编辑过
