[转帖]C#根据图片url保存图片到本地
2023年5月20日 8:51 本文热度 2454
传入图片链接,将该图片下载保存到指定位置,注意要做好图片安全校验。
using System;
using System.IO;
using System.Linq;
using System.Net;
using System.Text;
using System.Threading.Tasks;
namespace ConsoleApp1
  public static class SaveImgByUrl
    /// <summary>
    /// 调用方法
    /// </summary>
    public static void SaveImg()
      string imgurl = "https://img0.baidu.com/it/u=2229864841,4232235061&fm=26&fmt=auto";//图片地址
      string imgfile = "D:\\1.png";
      WriteBytesToFile(imgfile, GetBytesfromUrl(imgurl));
    /// <summary>
    /// 将数据流转化为图片保存到本地
    /// </summary>
    /// <param name="fileName"></param>
    /// <param name="content"></param>
    static public void WriteBytesToFile(string fileName, byte[] content)
      FileStream fs = new FileStream(fileName, FileMode.create);
      BinaryWriter w = new BinaryWriter(fs);
      try
        w.Write(content);
      finally
        fs.Close();
        w.Close();
    /// <summary>
    /// 根据url将图片转化为数据流
    /// </summary>
    /// <param name="url"></param>
    /// <returns></returns>
    static public byte[] GetBytesfromUrl(string url)
      byte[] b;
      HttpWebRequest myReq = (HttpWebRequest)WebRequest.create(url);
      WebResponse myResp = myReq.GetResponse();
      Stream stream = myResp.GetResponseStream();
      using (BinaryReader br = new BinaryReader(stream))
        b = br.ReadBytes(500000);
        br.Close();
      myResp.Close();
      return b;
https://www.cnblogs.com/work-code/p/15439616.html
该文章在 2023/5/20 8:51:41 编辑过
