[点晴永久免费OA]C#中listview控件点击列表头实现自动排序(文本/数字/时间)
2022年12月22日 20:14 本文热度 3063
#region 自定义变量
int currentCol = -1;
bool sort;
#endregion
//列头点击事件
private void lvw_ColumnClick(object sender, ColumnClickEventArgs e)
  string Asc = ((char)0x25bc).ToString().PadLeft(4, ' ');
  string Des = ((char)0x25b2).ToString().PadLeft(4, ' ');
  if (sort == false)
    sort = true;
    string oldStr = this.lvw.Columns[e.Column].Text.TrimEnd((char)0x25bc, (char)0x25b2, ' ');
    this.lvw.Columns[e.Column].Text = oldStr + Des;
  else if (sort == true)
    sort = false;
    this.lvw.Columns[e.Column].Text = oldStr + Asc;
  if(lvw.Columns[e.Column].Tag.ToString()=="text")//在设计器中把列头的tag设为"text",则表示该列按文本比较器处理
    lvw.ListViewItemSorter = new ListViewItemComparer(e.Column, sort);
  if(lvw.Columns[e.Column].Tag.ToString()=="num")//在设计器中把列头的tag设为"num",则表示该列按数字比较器处理
   lvw.ListViewItemSorter = new ListViewItemComparerNum(e.Column, sort);
 if(lvw.Columns[e.Column].Tag.ToString()=="time")//在设计器中把列头的tag设为"time",则表示该列按日期比较器处理
   lvw.ListViewItemSorter = new ListViewItemComparerTime(e.Column, sort);
  this.lvw.Sort();
  int rowCount = this.lvw.Items.Count;
  if (currentCol != -1)
    if (e.Column != currentCol)
      this.lvw.Columns[currentCol].Text = this.lvw.Columns[currentCol].Text.TrimEnd((char)0x25bc, (char)0x25b2, ' ');
  currentCol = e.Column;
//文本比较器
public class ListViewItemComparer : IComparer
  public bool sort_b;
  public SortOrder order = SortOrder.Ascending;
  private int col;
  public ListViewItemComparer()
    col = 0;
  public ListViewItemComparer(int column, bool sort)
    col = column;
    sort_b = sort;
  public int Compare(object x, object y)
    if (sort_b)
      return String.Compare(((ListViewItem)x).SubItems[col].Text, ((ListViewItem)y).SubItems[col].Text);
      return String.Compare(((ListViewItem)y).SubItems[col].Text, ((ListViewItem)x).SubItems[col].Text);
//数字比较器
public class ListViewItemComparerNum : IComparer
  public bool sort_b;
  private int col;
  public ListViewItemComparerNum()
    col = 0;
  public ListViewItemComparerNum(int column, bool sort)
    col = column;
    sort_b = sort;
    decimal d1=Convert.ToDecimal(((ListViewItem)x).SubItems[col].Text);
    decimal d2=Convert.ToDecimal(((ListViewItem)y).SubItems[col].Text);
    if (sort_b)
      return decimal.Compare(d1,d2);
      return decimal.Compare(d2,d1);
//日期比较器
public class ListViewItemComparerTime : IComparer
    public bool sort_b;
    private int col;
    public ListViewItemComparerTime()
        col = 0;
    public ListViewItemComparerTime(int column, bool sort)
        col = column;
        sort_b = sort;
        DateTime d1 = Convert.ToDateTime(((ListViewItem)x).SubItems[col].Text);
        DateTime d2 = Convert.ToDateTime(((ListViewItem)y).SubItems[col].Text);
        if (sort_b)
            return DateTime.Compare(d1, d2);
            return DateTime.Compare(d2, d1);
该文章在 2024/10/14 16:05:03 编辑过
