【C#】两个FTP服务器之间传送数据
2021年10月16日 14:36 本文热度 5048
using System;
using System.Data;
using System.Configuration;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using System.Net;
using System.IO;
using System.Text;
public class FtpUpDown
    string ftpServerIPout;
    string ftpServerIPin;
    string ftpUserIDout;
    string ftpUserIDin;
    string ftpPasswordout;
    string ftpPasswordin;
    FtpWebRequest reqFTPout;
    FtpWebRequest reqFTPin;
   public FtpUpDown(string ftpServerIPout, string ftpUserIDout,string ftpPasswordout,string ftpServerIPin, string ftpUserIDin ,string ftpPasswordin)
        this.ftpServerIPout = ftpServerIPout;
        this.ftpServerIPin=ftpServerIPin;
        this.ftpUserIDout = ftpUserIDout;
        this.ftpUserIDin = ftpUserIDin;
        this.ftpPasswordout = ftpPasswordout;
        this.ftpPasswordin = ftpPasswordin;
    private void Connect(string pathout, string pathin)//连接ftp
        // 根据uri创建FtpWebRequest对象
        reqFTPout = (FtpWebRequest)FtpWebRequest.Create(new Uri(pathout));
        // 指定数据传输类型
        reqFTPout.UseBinary = true;
        // ftp用户名和密码
        reqFTPout.Credentials = new NetworkCredential(ftpUserIDout, ftpPasswordout);
        reqFTPout.Method=WebRequestMethods.Ftp.DownloadFile;
        reqFTPin = (FtpWebRequest)FtpWebRequest.Create(new Uri(pathin));
        // 指定数据传输类型
        reqFTPin.UseBinary = true;
        // ftp用户名和密码
        reqFTPin.Credentials = new NetworkCredential(ftpUserIDin, ftpPasswordin);
        reqFTPin.Method = WebRequestMethods.Ftp.UploadFile;
   public bool Download(string fileName)/**/////上面的代码实现了从ftp服务器下载文件的功能
       try
            string urlout = "ftp://" + ftpServerIPout + "/" + fileName;
            string urlin = "ftp://" + ftpServerIPin + "/" + fileName;
            Connect(urlout, urlin);//连接
            FtpWebResponse response = (FtpWebResponse)reqFTPout.GetResponse();
            Stream ftpStream = response.GetResponseStream();
            long cl = response.ContentLength;
            int bufferSize = 2048;
            int readCount;
            byte[] buffer = new byte[bufferSize];
            readCount = ftpStream.Read(buffer, 0, bufferSize);
            Stream strm = reqFTPin.GetRequestStream();
            while (readCount != 0)
                strm.Write(buffer, 0, bufferSize);
            ftpStream.Close();
            strm.Close();
            response.Close();
            return true;
       catch
            return false;
后台调用:
protected void Button1_Click(object sender, EventArgs e)
          FtpUpDown ftpUpDown = new FtpUpDown("192.168.0.26", "tfds", "tfds","192.168.0.34","tfds","tfds");
          ftpUpDown.Download("2.txt");
          Response.Write("success");
该文章在 2021/10/16 14:36:18 编辑过
