【C#】LISTVIEW控件:文件/目录增加图标显示实例
2021年3月11日 1:55 本文热度 4313
说明:本例将目录中的文件显示在窗体的ListView控件中,并定义了多种视图浏览。通过调用Win32库函数实现图标数据的提取
主程序:
大图标:
列表:
详细信息:
Form1.cs:
1.  public partial class Form1 : Form
2.      {
3.          FileInfoList fileList;
4.
5.
6.          public Form1()
7.          {
8.              InitializeComponent();
9.          }
10.
11.
12.        private void 加载文件ToolStripMenuItem_Click(object sender, EventArgs e)
13.        {
14.            FolderBrowserDialog dlg = new FolderBrowserDialog();
15.            if (dlg.ShowDialog() == DialogResult.OK)
16.            {
17.                string[] filespath = Directory.GetFiles(dlg.SelectedPath);
18.                fileList = new FileInfoList(filespath);
19.                InitListView();
20.            }
21.        }
22.
23.
24.        private void InitListView()
25.        {
26.            listView1.Items.Clear();
27.            this.listView1.BeginUpdate();
28.            foreach (FileInfoWithIcon file in fileList.list)
29.            {
30.                ListViewItem item = new ListViewItem();
31.                item.Text = file.fileInfo.Name.Split('.')[0];
32.                item.ImageIndex = file.iconIndex;
33.                item.SubItems.Add(file.fileInfo.LastWriteTime.ToString());
34.                item.SubItems.Add(file.fileInfo.Extension.Replace(".",""));
35.                item.SubItems.Add(string.Format(("{0:N0}"), file.fileInfo.Length));
36.                listView1.Items.Add(item);
37.            }
38.            listView1.LargeImageList = fileList.imageListLargeIcon;
39.            listView1.SmallImageList = fileList.imageListSmallIcon;
40.            listView1.Show();
41.            this.listView1.EndUpdate();
42.        }
43.
44.
45.        private void 大图标ToolStripMenuItem_Click(object sender, EventArgs e)
46.        {
47.            listView1.View = View.LargeIcon;
48.        }
49.
50.
51.        private void 小图标ToolStripMenuItem_Click(object sender, EventArgs e)
52.        {
53.            listView1.View = View.SmallIcon;
54.        }
55.
56.
57.        private void 平铺ToolStripMenuItem_Click(object sender, EventArgs e)
58.        {
59.            listView1.View = View.Tile;
60.        }
61.
62.
63.        private void 列表ToolStripMenuItem_Click(object sender, EventArgs e)
64.        {
65.            listView1.View = View.List;
66.        }
67.
68.
69.        private void 详细信息ToolStripMenuItem_Click(object sender, EventArgs e)
70.        {
71.            listView1.View = View.Details;
72.        }
73.       }
FileInfoList.cs:
说明:主要用于后台数据的存储
1.  class FileInfoList
2.      {
3.          public List<FileInfoWithIcon> list;
4.          public ImageList imageListLargeIcon;
5.          public ImageList imageListSmallIcon;
6.
7.
8.          /// <summary>
9.          /// 根据文件路径获取生成文件信息,并提取文件的图标
10.        /// </summary>
11.        /// <param name="filespath"></param>
12.        public FileInfoList(string[] filespath)
13.        {
14.            list = new List<FileInfoWithIcon>();
15.            imageListLargeIcon = new ImageList();
16.            imageListLargeIcon.ImageSize = new Size(3232);
17.            imageListSmallIcon = new ImageList();
18.            imageListSmallIcon.ImageSize = new Size(1616);
19.            foreach (string path in filespath)
20.            {
21.                FileInfoWithIcon file = new FileInfoWithIcon(path);
22.                imageListLargeIcon.Images.Add(file.largeIcon);
23.                imageListSmallIcon.Images.Add(file.smallIcon);
24.                file.iconIndex = imageListLargeIcon.Images.Count - 1;
25.                list.Add(file);
26.            }
27.        }
28.    }
29.    class FileInfoWithIcon
30.    {
31.        public FileInfo fileInfo;
32.        public Icon largeIcon;
33.        public Icon smallIcon;
34.        public int iconIndex;
35.        public FileInfoWithIcon(string path)
36.        {
37.            fileInfo = new FileInfo(path);
38.            largeIcon = GetSystemIcon.GetIconByFileName(path, true);
39.            if (largeIcon == null)
40.                largeIcon = GetSystemIcon.GetIconByFileType(Path.GetExtension(path), true);
41.
42.
43.            smallIcon = GetSystemIcon.GetIconByFileName(path, false);
44.            if (smallIcon == null)
45.                smallIcon = GetSystemIcon.GetIconByFileType(Path.GetExtension(path), false);
46.        }
47.    }
GetSystemIcon:
说明:定义两种图标获取方式,从文件提取和从文件关联的系统资源中提取。
1.  public static class GetSystemIcon
2.      {
3.          /// <summary>
4.          /// 依据文件名读取图标,若指定文件不存在,则返回空值。
5.          /// </summary>
6.          /// <param name="fileName">文件路径</param>
7.          /// <param name="isLarge">是否返回大图标</param>
8.          /// <returns></returns>
9.          public static Icon GetIconByFileName(string fileName, bool isLarge = true)
10.        {
11.            int[] phiconLarge = new int[1];
12.            int[] phiconSmall = new int[1];
13.            //文件名 图标索引
14.            Win32.ExtractIconEx(fileName, 0, phiconLarge, phiconSmall, 1);
15.            IntPtr IconHnd = new IntPtr(isLarge ? phiconLarge[0] : phiconSmall[0]);
16.
17.            if (IconHnd.ToString() == "0")
18.                return null;
19.            return Icon.FromHandle(IconHnd);
20.        }
21.
22.
23.        /// <summary>
24.        /// 根据文件扩展名(如:.*),返回与之关联的图标。
25.        /// 若不以"."开头则返回文件夹的图标。
26.        /// </summary>
27.        /// <param name="fileType">文件扩展名</param>
28.        /// <param name="isLarge">是否返回大图标</param>
29.        /// <returns></returns>
30.        public static Icon GetIconByFileType(string fileType, bool isLarge)
31.        {
32.            if (fileType == null || fileType.Equals(string.Empty)) return null;
33.
34.
35.            RegistryKey regVersion = null;
36.            string regFileType = null;
37.            string regIconString = null;
38.            string systemDirectory = Environment.SystemDirectory + "\\";
39.
40.
41.            if (fileType[0] == '.')
42.            {
43.                //读系统注册表中文件类型信息
44.                regVersion = Registry.ClassesRoot.OpenSubKey(fileType, false);
45.                if (regVersion != null)
46.                {
47.                    regFileType = regVersion.GetValue(""as string;
48.                    regVersion.Close();
49.                    regVersion = Registry.ClassesRoot.OpenSubKey(regFileType + @"\DefaultIcon"false);
50.                    if (regVersion != null)
51.                    {
52.                        regIconString = regVersion.GetValue(""as string;
53.                        regVersion.Close();
54.                    }
55.                }
56.                if (regIconString == null)
57.                {
58.                    //没有读取到文件类型注册信息,指定为未知文件类型的图标
59.                    regIconString = systemDirectory + "shell32.dll,0";
60.                }
61.            }
62.            else
63.            {
64.                //直接指定为文件夹图标
65.                regIconString = systemDirectory + "shell32.dll,3";
66.            }
67.            string[] fileIcon = regIconString.Split(new char[] { ',' });
68.            if (fileIcon.Length != 2)
69.            {
70.                //系统注册表中注册的标图不能直接提取,则返回可执行文件的通用图标
71.                fileIcon = new string[] { systemDirectory + "shell32.dll""2" };
72.            }
73.            Icon resultIcon = null;
74.            try
75.            {
76.                //调用API方法读取图标
77.                int[] phiconLarge = new int[1];
78.                int[] phiconSmall = new int[1];
79.                uint count = Win32.ExtractIconEx(fileIcon[0], Int32.Parse(fileIcon[1]), phiconLarge, phiconSmall, 1);
80.                IntPtr IconHnd = new IntPtr(isLarge ? phiconLarge[0] : phiconSmall[0]);
81.                resultIcon = Icon.FromHandle(IconHnd);
82.            }
83.            catch { }
84.            return resultIcon;
85.        }
86.    }
87.
88.
89.    /// <summary>
90.    /// 定义调用的API方法
91.    /// </summary>
92.    class Win32
93.    {
94.        [DllImport("shell32.dll")]
95.        public static extern uint ExtractIconEx(string lpszFile, int nIconIndex, int[] phiconLarge, int[] phiconSmall, uint nIcons);
96.    }
该文章在 2021/3/11 1:55:41 编辑过
