C#使用aspose将Office文档转换为PDF代码(去除水印)
2020年4月3日 22:4 本文热度 6184
1、去除水印代码
public const string Key =
            "PExpY2Vuc2U+DQogIDxEYXRhPg0KICAgIDxMaWNlbnNlZFRvPkFzcG9zZSBTY290bGFuZCB" +
            "UZWFtPC9MaWNlbnNlZFRvPg0KICAgIDxFbWFpbFRvPmJpbGx5Lmx1bmRpZUBhc3Bvc2UuY2" +
            "9tPC9FbWFpbFRvPg0KICAgIDxMaWNlbnNlVHlwZT5EZXZlbG9wZXIgT0VNPC9MaWNlbnNlV" +
            "HlwZT4NCiAgICA8TGljZW5zZU5vdGU+TGltaXRlZCB0byAxIGRldmVsb3BlciwgdW5saW1p" +
            "dGVkIHBoeXNpY2FsIGxvY2F0aW9uczwvTGljZW5zZU5vdGU+DQogICAgPE9yZGVySUQ+MTQ" +
            "wNDA4MDUyMzI0PC9PcmRlcklEPg0KICAgIDxVc2VySUQ+OTQyMzY8L1VzZXJJRD4NCiAgIC" +
            "A8T0VNPlRoaXMgaXMgYSByZWRpc3RyaWJ1dGFibGUgbGljZW5zZTwvT0VNPg0KICAgIDxQc" +
            "m9kdWN0cz4NCiAgICAgIDxQcm9kdWN0PkFzcG9zZS5Ub3RhbCBmb3IgLk5FVDwvUHJvZHVj" +
            "dD4NCiAgICA8L1Byb2R1Y3RzPg0KICAgIDxFZGl0aW9uVHlwZT5FbnRlcnByaXNlPC9FZGl" +
            "0aW9uVHlwZT4NCiAgICA8U2VyaWFsTnVtYmVyPjlhNTk1NDdjLTQxZjAtNDI4Yi1iYTcyLT" +
            "djNDM2OGYxNTFkNzwvU2VyaWFsTnVtYmVyPg0KICAgIDxTdWJzY3JpcHRpb25FeHBpcnk+M" +
            "jAxNTEyMzE8L1N1YnNjcmlwdGlvbkV4cGlyeT4NCiAgICA8TGljZW5zZVZlcnNpb24+My4w" +
            "PC9MaWNlbnNlVmVyc2lvbj4NCiAgICA8TGljZW5zZUluc3RydWN0aW9ucz5odHRwOi8vd3d" +
            "3LmFzcG9zZS5jb20vY29ycG9yYXRlL3B1cmNoYXNlL2xpY2Vuc2UtaW5zdHJ1Y3Rpb25zLm" +
            "FzcHg8L0xpY2Vuc2VJbnN0cnVjdGlvbnM+DQogIDwvRGF0YT4NCiAgPFNpZ25hdHVyZT5GT" +
            "zNQSHNibGdEdDhGNTlzTVQxbDFhbXlpOXFrMlY2RThkUWtJUDdMZFRKU3hEaWJORUZ1MXpP" +
            "aW5RYnFGZkt2L3J1dHR2Y3hvUk9rYzF0VWUwRHRPNmNQMVpmNkowVmVtZ1NZOGkvTFpFQ1R" +
            "Hc3pScUpWUVJaME1vVm5CaHVQQUprNWVsaTdmaFZjRjhoV2QzRTRYUTNMemZtSkN1YWoyTk" +
            "V0ZVJpNUhyZmc9PC9TaWduYXR1cmU+DQo8L0xpY2Vuc2U+";
//使用下面代码前都加这个下面的
// new Aspose.Slides.License().SetLicense(new MemoryStream(Convert.FromBase64String(Key)));  //这个是sldes的,其他类似
2、配套代码(c#)
using Aspose.Cells;
using Aspose.Words;
using Aspose.Words.Fonts;
using System;
using System.Drawing;
using System.IO;
using System.Linq;
using System.Net;
using System.Net.Http;
using System.Web.Http;
using BorderType = Aspose.Cells.BorderType;
namespace manager.Controllers
    public class topdfController : ApiController   //webapi
        #region 把word转化成Pdf
        //转换成pdf
        // GET api/changepdf
        [HttpGet]
        public string changepdf(string ss)
            string path = System.Web.Hosting.HostingEnvironment.MapPath(ss);   //ss是文件名  gg.docx这样
            //return path;
            try
                string inpdf = path;
                string outpdf = @"/filedata/1111.pdf";             //输出文件
                new Aspose.Words.License().SetLicense(new MemoryStream(Convert.FromBase64String(Key)));
                string outtopdf = System.Web.Hosting.HostingEnvironment.MapPath(outpdf);   //计算出绝对路径
                //ExcelConvert.ExcelConvertManage.StartConvert(inpdf, outpdf);
                Document doc = new Document(inpdf);
                doc.Save(outtopdf, Aspose.Words.SaveFormat.Pdf);
                return outpdf;
            catch (Exception ex)
                return ex.Message;
        #endregion
        #region ppt转换为pdf
        //[Route("topdf/ppttopdf")]
        [HttpGet]
        public string ppttopdf(string ss)
            //return path;
            try
                //AsposeLicenseHelper.SetSlidesLicense();
                Aspose.Slides.Presentation doc = new Aspose.Slides.Presentation(inpdf);
                doc.Save(outtopdf, Aspose.Slides.Export.SaveFormat.Pdf);
                //doc.Save(outtopdf, Aspose.Words.SaveFormat.Pdf);
                return outpdf;
                return ex.Message;
        #endregion
        #region excel转换成pdf
        //[Route("topdf/exceltopdf")]
        [HttpGet]
        public string exceltopdf(string ss)
            //return path;
            try
                new Aspose.Cells.License().SetLicense(new MemoryStream(Convert.FromBase64String(Key)));
                Aspose.Cells.Workbook excel = new Workbook(inpdf);
                excel.Save(outtopdf, Aspose.Cells.SaveFormat.Pdf);
                return outpdf;
                return ex.Message;
        #endregion
配套aspose.dll
链接:https://pan.baidu.com/s/1kOG4rK7jxDk5yUjYhNa3VQ
提取码:g3iq
该文章在 2024/9/13 17:55:23 编辑过
全部评论1
2020年4月3日 22:19
点击生成wordtopdf
其中遇到以下错误:
原来是框架(.NET Framework 4 Client Profile)不合适,故换一种框架(点击项目---wordtopdf属性---目标框架---选择.NET Framework 4)再次运行没有错误
该评论在 2020/4/3 22:20:48 编辑过
