[点晴永久免费OA]c# 实现端口转发可以用来实现远程桌面连接内网主机
2019年6月27日 11:53 本文热度 4380
gYP.Start()方法调用后填写一台公网主机ip和端口(11111)然后公网主机用lcx转发11111到22222端口,远程桌面在公网主机连自己(127.0.0.1:22222)的22222端口就可以了可能需要点2次连接。
protected void wDZ(object sender, EventArgs e)
            if (iXdh.Text == "" || eEpm.Text.Length < 7 || ZHS.Text == "") return;
            PortForward gYP = new PortForward();
            gYP.Start(llH.Text, int.Parse(ZHS.Text), eEpm.Text, int.Parse(iXdh.Text));
        protected void vJNsE(object sender, EventArgs e)
            gYP.lyTOK();
        protected void tYoZ(object sender, EventArgs e)
    public class PortForward
        public string Localaddress;
        public int LocalPort;
        public string RemoteAddress;
        public int RemotePort;
        string type;
        Socket ltcpClient;
        Socket rtcpClient;
        Socket server;
        byte[] DPrPL = new byte[2048];
        byte[] wvZv = new byte[2048];
        public struct session
            public Socket rdel;
            public Socket ldel;
            public int llen;
            public int rlen;
        public static IPEndPoint mtJ(string host, int port)
            IPEndPoint iep = null;
            IPHostEntry aGN = Dns.Resolve(host);
            IPAddress rmt = aGN.AddressList[0];
            iep = new IPEndPoint(rmt, port);
            return iep;
        public void Start(string Rip, int Rport, string lip, int lport)
            try
                LocalPort = lport;
                RemoteAddress = Rip;
                RemotePort = Rport;
                Localaddress = lip;
                rtcpClient = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
                ltcpClient = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
                rtcpClient.BeginConnect(mtJ(RemoteAddress, RemotePort), new AsyncCallback(iiGFO), rtcpClient);
            catch (Exception ex) { }
        protected void iiGFO(IAsyncResult ar)
            try
                session RKXy = new session();
                RKXy.ldel = ltcpClient;
                RKXy.rdel = rtcpClient;
                ltcpClient.BeginConnect(mtJ(Localaddress, LocalPort), new AsyncCallback(VTp), RKXy);
        protected void VTp(IAsyncResult ar)
            try
                session RKXy = (session)ar.AsyncState;
                ltcpClient.EndConnect(ar);
                RKXy.rdel.BeginReceive(DPrPL, 0, DPrPL.Length, SocketFlags.None, new AsyncCallback(LFYM), RKXy);
                RKXy.ldel.BeginReceive(wvZv, 0, wvZv.Length, SocketFlags.None, new AsyncCallback(xPS), RKXy);
        private void LFYM(IAsyncResult ar)
            try
                int Ret = RKXy.rdel.EndReceive(ar);
                if (Ret > 0)
                    ltcpClient.BeginSend(DPrPL, 0, Ret, SocketFlags.None, new AsyncCallback(JTcp), RKXy);
                else lyTOK();
        private void JTcp(IAsyncResult ar)
            try
                RKXy.ldel.EndSend(ar);
                RKXy.rdel.BeginReceive(DPrPL, 0, DPrPL.Length, SocketFlags.None, new AsyncCallback(this.LFYM), RKXy);
        private void xPS(IAsyncResult ar)
            try
                int Ret = RKXy.ldel.EndReceive(ar);
                if (Ret > 0)
                    RKXy.rdel.BeginSend(wvZv, 0, Ret, SocketFlags.None, new AsyncCallback(IZU), RKXy);
                else lyTOK();
        private void IZU(IAsyncResult ar)
            try
                RKXy.rdel.EndSend(ar);
                RKXy.ldel.BeginReceive(wvZv, 0, wvZv.Length, SocketFlags.None, new AsyncCallback(this.xPS), RKXy);
        public void lyTOK()
            try
                if (ltcpClient != null)
                    ltcpClient.Close();
                if (rtcpClient != null)
                    rtcpClient.Close();
该文章在 2019/6/27 11:53:18 编辑过
