C#实现SQL SERVER数据库备份的两种方法比较
2018年1月30日 23:58 本文热度 8653
先把代码贴上吧
using System;
using System.Text;
using System.Data.SqlClient;
using System.Data;
using System.Windows.Forms;
namespace DBAdmin
    public class DbBackUpAndRestore
        /// <summary>
        /// 服务器
        /// </summary>
        private string server = "";
        public string Server
            get { return this.server; }
            set { this.server = value; }
        /// <summary>
        /// 登录名
        /// </summary>
        private string uid = "";
        public string UID
            get { return this.uid; }
            set { this.uid = value; }
        /// <summary>
        /// 登录密码
        /// </summary>
        private string pwd = "";
        public string PWD
            get { return this.pwd; }
            set { this.pwd = value; }
        /// <summary>
        /// 要操作的数据库
        /// </summary>
        private string database = "";
        public string Database
            get { return this.database; }
            set { this.database = value; }
        /// <summary>
        /// 数据库连接字符串
        /// </summary>
        private string conn = "";
        /// <summary>
        /// 备份路经
        /// </summary>
        private string backPath = "";
        public string BackPath
            get { return this.backPath; }
            set { this.backPath = value; }
        /// <summary>
        /// 还原文件路经
        /// </summary>
        private string restoreFile = "";
        public string RestoreFile
            get { return this.restoreFile; }
            set { this.restoreFile = value; }
        private ProgressBar bar;
        public ProgressBar Bar
            get { return bar; }
            set { bar = value; }
        /// <summary>
        /// DbBackUpAndRestore类的构造函数
        /// </summary>
        public DbBackUpAndRestore()
        /// <summary>
        /// 切割字符串
        /// </summary>
        /// <param name="str"></param>
        /// <param name="bg"></param>
        /// <param name="ed"></param>
        /// <returns></returns>
        public string StringCut(string str, string bg, string ed)
            string sub;
            sub = str.Substring(str.IndexOf(bg) + bg.Length);
            sub = sub.Substring(0, sub.IndexOf(";"));
            return sub;
        /// <summary>
        /// 构造文件名
        /// </summary>
        /// <returns>文件名</returns>
        private void CreatePath()
            string CurrTime = System.DateTime.Now.ToString();
            CurrTime = CurrTime.Replace("-", "");
            CurrTime = CurrTime.Replace(":", "");
            CurrTime = CurrTime.Replace(" ", "");
            CurrTime = CurrTime.Substring(0, 12);
            backPath += "//_db_" + CurrTime + ".BAK";
        private void Step(string message, int percent)
            Bar.Value = percent;
        /// <summary>
        /// 数据库备份
        /// </summary>
        /// <returns>备份是否成功</returns>
        public bool DbBackup()
            CreatePath();
            SQLDMO.Backup oBackup = new SQLDMO.BackupClass();
            SQLDMO.SQLServer oSQLServer = new SQLDMO.SQLServerClass();
            try
                oSQLServer.LoginSecure = false;
                oSQLServer.Connect(server, uid, pwd);
                oBackup.Action = SQLDMO.SQLDMO_BACKUP_TYPE.SQLDMOBackup_Database;
                SQLDMO.BackupSink_PercentCompleteEventHandler pceh = new SQLDMO.BackupSink_PercentCompleteEventHandler(Step);
                oBackup.PercentComplete += pceh;
                oBackup.Database = database;
                oBackup.Files = backPath;
                oBackup.BackupSetName = database;
                oBackup.BackupSetDescription = "数据库备份";
                oBackup.Initialize = true;
                oBackup.SQLBackup(oSQLServer);
                return true;
            catch (Exception ex)
                return false;
                throw ex;
            finally
                oSQLServer.DisConnect();
        /// <summary>
        /// 数据库恢复
        /// </summary>
        public string DbRestore()
            if (exepro() != true)
                return "操作失败";
                SQLDMO.Restore oRestore = new SQLDMO.RestoreClass();
                try
                    exepro();
                    oRestore.Action = SQLDMO.SQLDMO_RESTORE_TYPE.SQLDMORestore_Database;
                    SQLDMO.RestoreSink_PercentCompleteEventHandler pceh = new SQLDMO.RestoreSink_PercentCompleteEventHandler(Step);
                    oRestore.PercentComplete += pceh;
                    oRestore.Database = database;
                    ///自行修改
                    oRestore.Files = restoreFile;
                    oRestore.FileNumber = 1;
                    oRestore.ReplaceDatabase = true;
                    oRestore.SQLRestore(oSQLServer);
                    return "数据库恢复成功";
                catch (Exception e)
                    return "恢复数据库失败,原因:" + e.Message;
                    throw e;
                finally
        /// <summary>
        /// 杀死当前库的所有进程
        /// </summary>
        private bool exepro()
            bool success = true;
            SQLDMO.SQLServer svr = new SQLDMO.SQLServerClass();
            try
                svr.Connect(server, uid, pwd);
                //取得所有的进程列表
                SQLDMO.QueryResults qr = svr.EnumProcesses(-1);
                int iColPIDNum = -1;
                int iColDbName = -1;
                //找到和要恢复数据库相关的进程
                for (int i = 1; i <= qr.Columns; i++)
                    string strName = qr.get_ColumnName(i);
                    if (strName.ToUpper().Trim() == "SPID")
                        iColPIDNum = i;
                    else if (strName.ToUpper().Trim() == "DBNAME")
                        iColDbName = i;
                    if (iColPIDNum != -1 && iColDbName != -1)
                        break;
                //将相关进程关闭
                for (int i = 1; i <= qr.Rows; i++)
                    int lPID = qr.GetColumnLong(i, iColPIDNum);
                    string strDBName = qr.GetColumnString(i, iColDbName);
                    if (strDBName.ToUpper() == database)
                        svr.KillProcess(lPID);
                success = false;
            return success;
        public bool Operate(bool isBackup)
            //备份:use master;backup database @name to disk=@path;
            //恢复:use master;restore database @name from disk=@path;
            SqlConnection connection = new SqlConnection("Data Source=" + server + ";initial catalog=" + database + ";user id=" + uid + ";password=" + pwd + ";");
            if (!restoreFile.EndsWith(".bak"))
                restoreFile += ".bak";
            if (isBackup)//备份数据库
                SqlCommand command = new SqlCommand("use master;backup database @name to disk=@path;", connection);
                connection.Open();
                command.Parameters.AddWithValue("@name", Database);
                command.Parameters.AddWithValue("@path", restoreFile);
                command.ExecuteNonQuery();
                connection.Close();
            else//恢复数据库
                SqlCommand command = new SqlCommand("use master;restore database @name from disk=@path;", connection);
                connection.Open();
                connection.Close();
            return true;
第一种方法是利用库SQLDMO来进行数据库的备份和恢复。这种方法在恢复时,原数据不能正在使用当中,可以先把原数据库删除,适用于数据库误删除或者sql server数据库软件重装的情况下进行.当然这种情况下,发布时,必须把库SQLDMO打包。
第二种方式是通过调用sql指令来完成数据库的备份和还原。这种方法在恢复时,原数据必须存在,恢复时覆盖掉原数据库的数据。
备份的情况当然是数据库必须存在而且已经附加到数据库管理器中。
可以根据需要采用这两种方式
该文章在 2018/1/30 23:58:43 编辑过
