C#及JAVA之邮件服务器IMAP文件夹名称编码解码实现(支持中文名称)
2017年10月25日 11:19 本文热度 8310
IMAP邮件客户端中读取和创建邮件夹时需要对邮件夹名称进行编码和解码。该方法是通过网络上流传的perl语言方法改写的,配合InterIMAP项目可以编写完整IMAP邮件客户端。
InterIMAP项目地址: http://interimap.codeplex.com/
编码和解码方法,具体含义可以参考国际标准的定义:http://www.faqs.org/rfcs/rfc3501.html
C#:
//编码
private string IMAPEncode(string folder)
    string rtn = "", base64;
    int index = 0;
    Regex regAsis = new Regex(@"\G(?:[\x20-\x25\x27-\x7e])+");
    Regex reg26 = new Regex(@"\G&");
    Regex regEncode = new Regex(@"\G(?:[^\x20-\x7e])+");
    Regex regEq = new Regex(@"=+$");
    Regex regSlash = new Regex(@"\/");
    while (index < folder.Length)
        Match m;
        m = regAsis.Match(folder, index);
        if (m.Success)
            index = index + m.Length;
            rtn = rtn + m.Value;
            continue;
        m = reg26.Match(folder, index);
        if (m.Success)
            rtn = rtn + "&-";
            continue;
        m = regEncode.Match(folder, index);
        if (m.Success)
            base64 = Convert.ToBase64String(Encoding.GetEncoding("UTF-16BE").GetBytes(m.Value));
            base64 = regEq.Replace(base64, "");
            base64 = regSlash.Replace(base64, ",");
            rtn = rtn + "&" + base64 + "-";
            continue;
    return rtn;
// 解码
private string IMAPDeconde(string folder)
    int index = 0;
    Regex regAsis = new Regex(@"\G([^&]+)");
    Regex reg26 = new Regex(@"\G\&-");
    Regex regDecode = new Regex(@"\G\&([A-Za-z0-9+,]+)-?");
    Regex regComma = new Regex(@",");
        Match m;
        if(m.Success)
            continue;
        if(m.Success)
        { index = index + m.Length;
            rtn = rtn + "&";
            continue;
        m = regDecode.Match(folder, index);
        if(m.Success)
            base64 = m.Value.Substring(1, m.Value.Length - 2);
            base64 = regComma.Replace(base64, "/");
            int mod = base64.Length % 4;
            if(mod > 0 )
                int count = 4 - mod;
                while (count > 0)
                    base64 += "=";
                    count--;
                //base64 = base64.PadRight(base64.Length + (4 - mod), "=");
            base64 = Encoding.GetEncoding("UTF-16BE").GetString(Convert.FromBase64String(base64));
            rtn = rtn + base64;
            continue;
    return rtn;
JAVA:
  1. ImapFolderEncoder {
  2.     public static String encode(String folder) {
  3.     String rtn = "", base64;
  4.     int index = 0;
  5.     Pattern regAsis = Pattern.compile("\\G(?:[\\x20-\\x25\\x27-\\x7e])+");
  6.     Pattern reg26 = Pattern.compile("\\G&");
  7.     Pattern regEncode = Pattern.compile("\\G(?:[^\\x20-\\x7e])+");
  8.     Pattern regEq = Pattern.compile("=+$");
  9.     Pattern regSlash = Pattern.compile("\\/");
  10.     while (index < folder.length()) {
  11.         Matcher m;
  12.         m = regAsis.matcher(folder);
  13.         if (m.find(index)) {
  14.         index = index + (m.end() - m.start());
  15.         rtn = rtn + m.group();
  16.         continue;
  17.         }
  18.         m = reg26.matcher(folder);
  19.         if (m.find(index)) {
  20.         index = index + (m.end() - m.start());
  21.         rtn = rtn + "&-";
  22.         continue;
  23.         }
  24.         m = regEncode.matcher(folder);
  25.         if (m.find(index)) {
  26.         index = index + (m.end() - m.start());
  27.         base64 = SimpleUtil.encodeBase64Content(m.group(), "UTF-16BE");
  28.         base64 = base64.replaceAll(regEq.pattern(), "");
  29.         base64 = base64.replaceAll(regSlash.pattern(), ",");
  30.         rtn = rtn + "&" + base64 + "-";
  31.         continue;
  32.         }
  33.     }
  34.     return rtn;
  35.     }
  36.
  37. }
  1. ImapFolderDecoder {
  2.     public static String decode(String folder) {
  4.     int index = 0;
  5.     Pattern regAsis = Pattern.compile("\\G([^&]+)");
  6.     Pattern reg26 = Pattern.compile("\\G\\&-");
  7.     Pattern regDecode = Pattern.compile("\\G\\&([A-Za-z0-9+,]+)-?");
  8.     Pattern regComma = Pattern.compile(",");
  9.     while (index < folder.length()) {
  10.         Matcher m;
  11.         m = regAsis.matcher(folder);
  12.         if (m.find(index)) {
  13.         index = index + (m.end() - m.start());
  14.         rtn = rtn + m.group();
  15.         continue;
  16.         }
  17.         m = reg26.matcher(folder);
  18.         if (m.find(index)) {
  19.         index = index + (m.end() - m.start());
  20.         rtn = rtn + "&";
  21.         continue;
  22.         }
  23.         m = regDecode.matcher(folder);
  24.         if (m.find(index)) {
  25.         index = index + (m.end() - m.start());
  26.         base64 = m.group().substring(1, m.group().length() - 1);
  27.         base64 = base64.replaceAll(regComma.pattern(), "/");
  28.         int mod = base64.length() % 4;
  29.         int count = 4 - mod;
  30.         while (count > 0) {
  31.             base64 += "=";
  32.             count--;
  33.         }
  34.         base64 = SimpleUtil.base64Decode(base64, "UTF-16BE");
  35.         rtn = rtn + base64;
  36.         continue;
  37.         }
  38.     }
  39.     return rtn;
  40.     }
  41. }
该文章在 2017/10/25 14:27:59 编辑过
